14 years ago --- Quote Start --- Yes, Not running as in not making timings, although the analyzer says I am. I have some violations with one particular clock that is not involved in the relevant circuits at all. I can disable it and the violations will go away. Then nothing is in red any more except for the report of unconstrained paths. --- Quote End --- Hi, you observed the problem with signaltap. It is also possible that you have a problem with capturing the signals. Could you verify that your design shows a "real" misbehaviour ? Kind regards GPK
