11 years ago[TimeQuest] false paths to/from/inside an hierarchy -> how to?
Hi All, As for the TimeQuest, how can I put a false path for all the signals coming to/from a specific hierarchy and also for the signals inside of the hierarchy? Thank you
11 years agoThis would ONLY apply between flops, as that is all that is timed (except IO pins).
What are you trying to cut? you realise that false paths basically just set an ignore list for timequest. You should be careful with false paths and ensure there really is no timing relationship between the two flops.
