10 years agoTimequest difference between 11.1sp1 and 13.1
Have an SDC file with this constraint for some data output signals:
set Clock100p0MHz PLL:inst28|……..auto_generated|wire_pll1_clk[3] set_output_delay -add_delay -max 1.0 -clock $Clock100p0MHz [get_ports SomeSignals*] With 11p1sp1, Timequest sees the set_output_delay as a valid command, but in 13.1 and 15.1, TimeQuest throws an error saying that there is no such clock “Clock100p0MHz” is there a different way now to constrain IO pins?1 Reply
--- Quote Start --- Have an SDC file with this constraint for some data output signals: set Clock100p0MHz PLL:inst28|……..auto_generated|wire_pll1_clk[3] set_output_delay -add_delay -max 1.0 -clock $Clock100p0MHz [get_ports SomeSignals*] With 11p1sp1, Timequest sees the set_output_delay as a valid command, but in 13.1 and 15.1, TimeQuest throws an error saying that there is no such clock “Clock100p0MHz” is there a different way now to constrain IO pins? --- Quote End --- Maybe recompilation changed "auto_generated|wire_pll1_clk[3]" signal name?
