13 years agoJust thought I would chime in here. I've recently discovered that the PROPER method of constraining a purely asynchronous interface (like the DE2-115's async SRAM) is by using the Synopsys Design Constraint's 'set_data_check' command. Unfortunately, Altera does not support that particular command (they only support a subset of the full SDC syntax). Bummer! But if they ever do support it the appropriate syntax would be similar to this:
set_data_check -setup 2 -from o_SRAM_WE_n -to io_SRAM_Data
The above command says, "io_SRAM_Data must arrive 2ns before o_SRAM_WE_n". You would obviously get the appropriate setup time value from the SRAM's datasheet. The command is similar for the hold constraint: set_data_check -hold 1 -from o_SRAM_WE_n -to io_SRAM_Data
The above is how you would constrain an asynchronous SRAM interface on an ASIC design using, for example, Synopsys Design Compiler and PrimeTime. Cya!
