Altera_ForumHonored Contributor14 years ago[TimeQuest] constraining block-RAM Hello, I'm not TQ expert, so I have some simple questions - how to constrain internal memory in fpga? Esp. dual-port RAM with different rd/wr clocks? Can single-port memory be constrained with ...Show More
Altera_ForumHonored Contributor14 years agoNo. Just constrain the clocks and the memory will be constrained from that.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
