11 years agoTimeQuest Clock Assignments
Hi All,
I'm closing the timing on a design using the EP3C5 series Cyclone III and there is a discrepancy on some of my signals as to which clock they are being assigned. I have three main clocks; the primary system clock, a USB clock for serial communication, and a read clock coming off a microprocessor for taking the output data from the FPGA. In my TQ reports though, several signals are reported as being clocked by the wrong source (ie - the signal should be controlled by the system clock but is being reported as being clocked by the USB clock). Is there a tcl command I need to be using to make sure my signals are clocked by the right source? If TQ is reporting my clock assignments incorrectly, will I see improper behavior of my design?
