toczkows
3 years agoTimeQuest ALTPLL wrong setup relation
recently I found some strange behaviour of timequest STA regarding simple design with PLL on Quartus Prime Lite. If there is simple data transfer between clock (i_CLK) and clock that's output ...
Nurina
3 years agoHello,
Have you tried the solution I have provided?
By the way, engineering has responded. Can you let me know why you are setting an offset to the base clock? What's the use case?
Nurina
