toczkows
3 years agoTimeQuest ALTPLL wrong setup relation
recently I found some strange behaviour of timequest STA regarding simple design with PLL on Quartus Prime Lite. If there is simple data transfer between clock (i_CLK) and clock that's output ...
Nurina
3 years agoHi,
Engineering is still investigating the problem here.
I've tried experimenting by adding phase shift in the PLL.
With below SDC constraints,
create_clock -name {i_clk} -period 10.000 -waveform { 4.000 9.000 } [get_ports {i_clk}]
derive_pll_clocks
derive_clock_uncertainty
Added below changes to the PLL:
The setup & hold relationship is 10ns & 0ns respectively:
Setup Report Timing
Hold Report Timing
Can you try this solution?
Nurina
