toczkows
3 years agoTimeQuest ALTPLL wrong setup relation
recently I found some strange behaviour of timequest STA regarding simple design with PLL on Quartus Prime Lite. If there is simple data transfer between clock (i_CLK) and clock that's output ...
Nurina
3 years agoHi,
Shifting a clock will change the setup and hold relationship because then the launch and latch edge will be changing. By default, TimeQuest will choose the nearest latch edge and this results in a different setup & hold relationship. If the setup & hold relationship calculated by TimeQuest is not what you want, you should use set_multicycle_path.
Nurina
