8 years agotime limited sof file generation
Hi, I observed the following behaviour using Quartus 17.0. When i start to add my own custom IP into the qsys, then the time_limited sof file is generated and the behaviour of my eclipse ...
8 years agoCan you go to the assembler report and check the "Encrypted Cores Summary"?
If you don't know how to get it, go to the "Tasks" view on the left, and in the hierarchical list open "Compile Design", then "Assembler (Generate programming files)" and double-click on "View Report". Then in the report, choose "Encrypted Cores Summary". It should show you a list of all the cores that you used that require a license. It should tell you exactly which core you used that made your sof file time limited.
