17 years ago --- Quote Start --- A few things to mention: 1 - It looks like you're getting confused in your signal names. You're using a signal called data but you're also using a signal called input. Are they supposed to be the same thing? 2 - You should never use the names "input" or "output" to name signals. Those are keywords in Verilog and should only be used when declaring inputs and outputs to a module, task, or function. 3 - You're event triggerred always block. You need to keep in mind that what you are writing is going to be turned into hardware. Flip-flops in hardware have a single clock input. You cannot use a rising and falling edge of a signal as a clock input to a flip-flop. Your code is actually not synthesizable. You have a clock input, data input, and a asynchronous set and/or reset signal at your disposal. 4 - It's good practice to provide a reset signal to initialize your registers to a pre-determined state. Does this meet your needs? I haven't compiled it so there might be a syntax error or two:
module ocd(
input clk, // clock
input reset_n, // active low reset
input data_in,
output data_out
reg last_data;
reg counter;
wire edge;
assign edge = last_data ^ data_in;
always @(posedge clk or negedge reset_n) begin
if(!reset_n) begin
data_out <= 1'b0;
last_data <= 1'b0;
counter <= 3'd0;
end else begin
last_data <= data_in;
counter <= counter + 3'd1;
if(edge) counter <= 3'd3;
else if(counter == 5) begin
counter <= 3'd1;
data_out <= data_in;
end
end
end
endmodule
--- Quote End --- Sorry for the typo. Yes input means the data, as the keywords wont even compile successfully. According to ur code, edge is high only for a short amount of time. so if edge is high only between two clock pulses and goes back to low before the next clock pulse, the edge wont be detected in such case. right?
