11 years agoThis is a typical program for traffic light controller without a test bench
I got two errors while synthesizing the program and the VHDL code is ..........
Library IEEE; use IEEE.std_logic_1164.all; package lights is subtype light is bit_vector(0 to 1); constant red: light := B"00"; constant green : light := B"01"; constant yellow : light := B"10"; end lights; use WORK.lights.all; entity traff is port(clock : in Bit; reset: in Bit; cars : in Bit; short,long : in Bit; highway_light : out light := green; farm_light : out light := red; start_timer : out Bit ); end; -- define light controllers behavior => architecture register_transfer of traff is type ctrl_state_type is(hg,hy,fg,fy); signal ctrl_state,ctrl_next : ctrl_state_type := hg; begin ctrl_proc_combin : process(ctrl_state,short,long,cars) begin if reset = '1' then ctrl_next <=hg; else case ctrl_state is when hg => highway_light <= green; farm_light <= red; if (cars and long )= '1' then ctrl_next <= hy; start_timer <='1'; else ctrl_next <=hg; start_timer <= '0'; end if; when hy => highway_light <= yellow;farm_light <= red; if short = '1' then ctrl_next <= hg; start_timer <= '1'; else ctrl_next <= hy; start_timer <= '0'; end if; when fg => highway_light <= red; farm_light <= green; if ( not cars or long ) = '1' then ctrl_next <= fy ; start_timer <= '1'; else ctrl_next <= fg ; start_timer <= '0'; end if; when fy => highway_light <= red; farm_light <= yellow; if short = '1' then ctrl_next <= hg;start_timer <= '1'; else ctrl_next <= fy; start_timer <= '0'; end if; end case; end if; end process ctrl_proc_combin; => sync:process(CLOCK) begin wait until CLOCK'event and CLOCK = '1'; ctrl_state <= ctrl_next; end process sync; end register_transfer; And my error is Line 67: Process cannot have both a wait statement and a sensitivity list. Line 24: Unit <register_transfer> ignored due to previous errors.2 Replies
Error is quite clear. You can't have a sensitivity list and a wait statement in a process. I suggest you read a vhdl tutorial to get valid process templates for various constructs
Thank YOu sir.........
