11 years agoThe signal does not hold its value outside clock edge
Please help me with an error in my code. I need that when a button is pressed, the signal changes its value. But the quartus says he can not infer a register for it. I found a resolution, which ...
11 years agoI see that there are two lines commented out, these change the functionality of the code enormously as the END IF is for the second for loop. Was this something you did to try and get it working?
