sunin
4 years agoThe routing delay is 0 ns in quartus chipplanner
I designed a program about TDC. However,i found the routing delay is 0 ns when i check its timming by Timequest.Shown below, the Tco is 0.073ns,but the routing delay is 0 ns.
chip planner
RichardT_altera
3 years agoSorry for the delay in response. It seems that the timing path comes from the LPM_ADD_SUB IP itself.
I believe the IP function correctly and the 0ns routing delay could be an expected behavior.
Do you see any problem when you try to run simulation with the current design?
