sunin
4 years agoThe routing delay is 0 ns in quartus chipplanner
I designed a program about TDC. However,i found the routing delay is 0 ns when i check its timming by Timequest.Shown below, the Tco is 0.073ns,but the routing delay is 0 ns.
chip planner
RichardT_altera
4 years agoI do not have the answer with the current info provided.
I will need to get your design to further investigate this. Could you share the design .qar file?
Which Quartus Pro version and devices are you using?
sunin
3 years agoAre you still there? In my opinion, thare are different delays between adjacent LEs especially between adjacent LABs. However, the routing delay created in 16-bit adder is not like this. The 16-bit adder project shown below has played STA, and the delays are similar. I will so appreciate it if you can reply to me ==||
