sunin
4 years agoThe routing delay is 0 ns in quartus chipplanner
I designed a program about TDC. However,i found the routing delay is 0 ns when i check its timming by Timequest.Shown below, the Tco is 0.073ns,but the routing delay is 0 ns.
chip planner
RichardT_altera
4 years agoI do not have the answer with the current info provided.
I will need to get your design to further investigate this. Could you share the design .qar file?
Which Quartus Pro version and devices are you using?
sunin
4 years agoEspecially, the code is designed at Quartus prime standrad edition and EP4CE10F17C8.
