sunin
4 years agoThe routing delay is 0 ns in quartus chipplanner
I designed a program about TDC. However,i found the routing delay is 0 ns when i check its timming by Timequest.Shown below, the Tco is 0.073ns,but the routing delay is 0 ns.
chip planner
RichardT_altera
4 years agoWow, that is a huge negative slack! I will look into why the clock skew is so high and start work from there first. 2.347 is too high.
Before that, check if the timing path is relevant as Timing Analyzer will analyze all paths. If not, set false path to tell the tool to exclude that path.
You may checkout the Best Design Practices for Timing Closure:
https://www.youtube.com/watch?v=UGGkKZylJBo&t=122s
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
sunin
4 years agoI designed a 16-bit full adder. Its routing delay between adjacent LABs is 0 ns as similar as the figure above. Both are wrong obviously, but what else can I do?
