15 years ago@Lewis: have you resolved?
I've the same problem: RTL works, whereas Gate-level firstly had the "Failed to find INSTANCE" problem and after renaming settings I've that all stimulus do not move (seems as Modelsim do not use the testbench file) I've the test bench module that is : tb_top.vhd My quartus II v10sp1 design top is: top.vhd In attachment you can find the 2 .vhd files and an image of the settings of simulator. If some can help I'll be pleased. Best regards
