The loanIO confusions
Hi CAlex,
There was some on-going conversations from the previous comments. I didnt manage to understand the problems which are still not being resolved on your end.
Would like to know the focus on the problems that are still present?
Aik Eu
Hi
Now Im totally confused by the directions:
I have three parts:
hardware IO : HTX , HRX.
software IO :STX,SRX.
generally HTX -> SRX , HRX <- STX.
Now I borrowed the HPS IO to the FPGA, they are MISO(59) and MOSI(58).
If I didnt misunderstand the meaning of h2f_loan_io_in/out/oe
Version 1
MISO(59) should be HPS output(oe = 1) linked to HRX,which means links to STX
MOSI(58) should be HPS input(oe = 0) linked to HTX,which means links to SRX
However
loan_io_in means FPGA output to HPS input
Version 2
MISO(59) should be HPS output (oe = 1) linked to SRX,which means links to HTX
MOSI(58) should be HPS input (oe = 0) linked to STX,which means links to HRX
Who can tell me which one is right? <---------------- not solved
And do I need to write the HPS code / pre-loader, if needed ,how? (solved)
Reguards.
I just want to know when I wrote a UART RS232 IP with SRX and STX, linked to the hardware HTx and HRx, the LoanIO MISO and MOSI should be output or input (set oe == 1 or 0 , wire loanIO_out/in assigned to SRX and STX).
Reguards
