The loanIO confusions
Hi CAlex,
There was some on-going conversations from the previous comments. I didnt manage to understand the problems which are still not being resolved on your end.
Would like to know the focus on the problems that are still present?
Aik Eu
- CAlex3 years ago
Contributor
Hi
Now Im totally confused by the directions:
I have three parts:
hardware IO : HTX , HRX.
software IO :STX,SRX.
generally HTX -> SRX , HRX <- STX.
Now I borrowed the HPS IO to the FPGA, they are MISO(59) and MOSI(58).
If I didnt misunderstand the meaning of h2f_loan_io_in/out/oe
Version 1
MISO(59) should be HPS output(oe = 1) linked to HRX,which means links to STX
MOSI(58) should be HPS input(oe = 0) linked to HTX,which means links to SRX
However
loan_io_in means FPGA output to HPS input
Version 2
MISO(59) should be HPS output (oe = 1) linked to SRX,which means links to HTX
MOSI(58) should be HPS input (oe = 0) linked to STX,which means links to HRX
Who can tell me which one is right? <---------------- not solved
And do I need to write the HPS code / pre-loader, if needed ,how? (solved)
Reguards.
I just want to know when I wrote a UART RS232 IP with SRX and STX, linked to the hardware HTx and HRx, the LoanIO MISO and MOSI should be output or input (set oe == 1 or 0 , wire loanIO_out/in assigned to SRX and STX).
Reguards
