substitute your instruction:
default:begin end
with
default:
begin
RsutCPID0<=1'bx;
Add all the signals that are defined in the procedural block
end
In the sensitivity list : always @(CurloopCal)
add the signals that are on the right side of the assignments such as: Cerr0
always @(CurloopCal,Cerr0)
This won't solve all the problems. As example you write: sumce <= sumce+Cerr0;
That can waork only if a register holds the sumce value and the procedural block is sychronized with the clock.
I suggest to read a book on Verilog for synthesis.
