16 years agoHi,
The SRAM chip is on the DE1 board itself. After downloading the file, maybe using RealTerm, then the file will be saved on the SRAM chip.Here are my problems: 1. How do I load the file from PC to the board through RS232? Is it just load the file using RealTerm and transfer, just that simple? 2. How can I make sure that the file already been loaded to the SRAM? What code i have to write to check? Thanks!
