FSamb
8 years agoTest kernel that uses IO channel reads from Global Memory more than expected
What kernel does is just read from Global Memory, then write the same data to write IOchannel. Since reads from GM always has extra reads, it affects the behavior of the write to IO channel.
FSamb
7 years agoHi, Arslan.
Thanks for replying.
Fortunately, the problem is already fixed. IO channel working now. It could be that the strange behavior that I was observing was due to my mistake in the reset that I used for my fifo. Can't explain how they are related. IO channel is a bit hard to debug as it involves multiple FPGAs. Anyway, thanks again for the help. Sorry for the trouble.
On Thu, Nov 8, 2018, 8:04 AM Intel Forums <[email protected] wrote:
