--- Quote Start ---
Hi thanks for advice, but when i delete the sensitivity list then i cant processed the code, i try this way.,but no progress
--- Quote End ---
You should consider being more specific about what you mean...it's totally unclear about where you're having problems. Below is some code (untested, not even compiled, up to you to fix) that will generate the stimulus to test your widget
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use ieee.numeric_std.all;
ENTITY Block4CLA_vhd_tst IS
END Block4CLA_vhd_tst;
ARCHITECTURE Block4CLA_arch OF Block4CLA_vhd_tst IS
-- constants
constant CLOCK_PERIOD: time := 100 ns;
-- signals
SIGNAL carry_in : STD_LOGIC;
SIGNAL clock : STD_LOGIC := '0';
SIGNAL Cout : STD_LOGIC;
SIGNAL D : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL Q : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL Resetn : STD_LOGIC;
signal Sim_Complete: std_logic := '0';
BEGIN
i1 : entity work.Block4CLA
PORT MAP
-- list connections between master ports and signals
carry_in => carry_in,
clock => clock,
Cout => Cout,
D => D,
Q => Q,
Resetn => Resetn
clock <- not(clock) and not(Sim_Complete) after (CLOCK_PERIOD / 2);
Resetn <= '0', '1' after 201 ns;
Main : process
begin
d <= "0000";
carry_in <= '0';
wait until (Resetn = '1') and rising_edge(Clock);
for c in 0 to 1 loop
if (c = 0) then
carry_in <= '0';
else
carry_in <= '1';
end if;
for d_loop in 0 to 15 loop
d <= std_logic_vector(to_unsigned(d_loop, d'length));
wait until rising_edge(clock);
-- Add assertions here to check that the outputs Q and Cout are correct
end loop;
end loop;
Sim_Complete <= '1';
wait;
end process Main;
END Block4CLA_arch;
Kevin Jennings
