lambert_yu's avatar
lambert_yu
5 years ago
Tere is error when creat Traffic Generator Connection
Hi all,
I face one problem, when I use EMIF debug toolkit to test DDR4 board which is build by myself, and I get one example design under customize the requirement of the DDR4 which I need when I generate the EMIF IP. I compiled this example, and downloading .sof file into fpga. I open the EMIF debug toolkit and can create Memory Interface Connection, I can make sure that the calibration is completed and successful and can re-calibrate the IP through downloading the intruction through the EMIF DEBUG TOOLKIT to the IP. But when I creat Traffic Generator Connection, there is always one error that blocks me to do next operation.
About the information: I enable " Add EMIF Debug Interface" and select " Use configurable Avalon traffic generator 2.0" & Export Traffic Generator 2.0 configuration interface.
The error picture :
 So about my problem, could one give me some advice?
Brs,
Lambert
  • sstrell's avatar
    sstrell
    What is your target device and what version of Quartus are you using?
    • lambert_yu's avatar
      lambert_yu
      hi sstre,
      The target device is arria 10 10ax115n2f45e1sg
      generated EMIF IP VersiOn :quartus pro 17.1
      debug version :quartus pro 17.0
      brs,
      lambert
