Tere is error when creat Traffic Generator Connection
What is your target device and what version of Quartus are you using?
hi sstre,
The target device is arria 10 10ax115n2f45e1sg
generated EMIF IP VersiOn :quartus pro 17.1
debug version :quartus pro 17.0
brs,
lambert
- sstrell5 years ago
The Traffic Generator 2.0 (TG2) is not supported in that old version of Quartus. You need to use at least 20.1 Pro.
Why it was an option in older versions of the tools is a mystery.
This training goes into detail on TG2. The training refers to Agilex, but I think it's supported in Arria 10 as well:
https://www.intel.com/content/www/us/en/programmable/support/training/course/oagmem104.html
- lambert_yu5 years ago
Contributor
Hi sstrell,
Though I can not create the Traffic Generator connection through EMIF Debug toolkit, that means I can not use many feature of the TG2.0 tool, I want to know if the traffic_gen_pass is asserted after TG2.0 IP in example project runover the some pattern (default traffic pattern, repeated-writes/repeated-reads test pattern, and stress pattern) under one datarate, can I think that the EMIF IP works well at the current frequency?
Brs,
Lambert
Whenever you reset the TG (TG or TG2), it goes through its pattern. But as mentioned, you're going to have to change your options to use the original TG and recompile your project to make this work unless you move to 20.1 or later (but even then you'd have to regenerate and recompile).
