11 years agoTerasic PCIe example designs unable to decrypt files
Hi all, I am trying to compile some reference designs (specifically PCIe_Fundamental and PCIe_ImageProcess) bundled with the Terasic DE5-Net. When I try to compile the projects, I first get an ...
11 years agoStarting in Quartus II 14.0, generally the transceiver instances should have switch to "PHY" instead of "ALT". Just wonder if you have tried to upgrade all the instances? You can try to archive the older design and then re-open the QAR in Quartus 15.0. It should help to perform auto-upgrade on all the older version IPs. If issue still persist, you might want to try re-instantiate that particular IP in Quartus 15.0.
