MBrom6
5 years agoH KhaiY,
sorry for the late reply, we have some license issues on our server at the moment.
However, I have tested your solution locally and it works for the example design.
I did not expect that the sdc file is not part of the project by default. So, I did not checked this.
Adding the example sdc solved the error.
I will apply the same solution to our design now. As the synthesis will require some time, I will give you an update once it is finished.
Thank you.
Michael
