13 years agoTCL commands to export calibration report in external memory interface toolkit (EMIF)
I'm trying to find TCL commands to export calibration and margin reports in external memory interface toolkit (EMIF)
There are lots of examples of how to export design and timing analysis reports. But not EMIF reports. EMIF does allow exporting reports from GUI, though. I don't believe it's not supported as TCL commands. Specifically, it has to be somewhere in ::quartus::report package. Thanks, Evgeni2 Replies
I am also looking for a solution to export calibration report from the command line. Please post the answer if you already found it.
Thanks, Gokul - Altera_Forum
All,
I have figured a way to do this. Please find the TCL below: # ----------------- # Report Export load_package report load_report_database -type emit set panel "*Per DQS Group Calibration" set id [get_report_panel_id $panel] write_report_panel -file DDR_Per_DQS_Calibration_Report.xml -xml -id $id # ------------------ Thanks, Gokul
