10 years agoTCL command to check for clock assignment
I'm looking for a TCL command to find if a given port/pin has already been assigned a clock with create_clock/create_generated_clock. Cheers.1 Reply
This is not quite what you are asking, but I typically use the .sdc syntax:
This checks to see if a clock has been used in a design, and if it has, then assigns a default clock contraint, and group. Cheers, Daveset ports if { == 1} { set clkin_50MHz_period 20 set name clkin_50MHz puts " ==> S4GXDK: constrain clock $name" create_clock -period $clkin_50MHz_period -name $name set_clock_groups -exclusive -group $name }
