8 years agotask vs always
Hello, i know that always executes always when some parameter in the sensitivity list changes. in what cases task executes? if i have a task block and always block one after the other' which one...
8 years ago --- Quote Start --- What do you mean by this? A task is a procedure that must be called by from a running process. An always block is a continuously running process. --- Quote End --- Maybe Im getting myself confused. In VHDL a procedure can be called outside of a process and in doing so you have an implicit process. I thought the same could be done in verilog - mistaken.
