8 years agotask vs always
Hello, i know that always executes always when some parameter in the sensitivity list changes. in what cases task executes? if i have a task block and always block one after the other' which one...
8 years ago --- Quote Start --- A task has to be called. Hence it needs to be called from inside an always or initial block. A task block on it's own will be called as an implicit always. --- Quote End --- What do you mean by this? A task is a procedure that must be called by from a running process. An always block is a continuously running process.
