11 years ago --- Quote Start --- why not post the code you used.... And what is the "proper count"? the code you origionally posted is a down counter. --- Quote End --- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity dwncounter is port( clk,rst:in std_logic; enable:in std_logic; count:out std_logic_vector(3 downto 0) ); end dwncounter; architecture behavioral of dwncounter is signal counter:std_logic_vector(3 downto 0):="1111" begin process(clk,rst) begin if (rst='1') then counter<=(others=>'0'); elsif rising_edge(clk) then if(enable='1'and counter/="0000") then counter<=counter-1; end if; end if; end process; count<=counter; end behavioral;
