16 years agoWhat does it mean to change the portmap to be what you specified? I'm not famililar with the => notation. I changed it to exactly how you specified but I'm still missing the first value that I try to write. To me it looks like the first value is just never written to memory. To test it out I made a simple wave form with a valid signal that's high for a cycle (starting when clock is low, ending when clock is high) and I also have an input in that same cycle. At the falling edge, I see my output for the rising edge, and thats when the address appears but that first value isn't written.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity framestore is
port
clk,reset : in std_logic;
input: in std_logic_vector(3 downto 0);
valid: in std_logic;
readEN: in std_logic;
rwaddressstart: in std_logic_vector(14 downto 0);
output : out std_logic_vector(3 downto 0);
addressout: out std_logic_vector(14 downto 0);
holdout: out std_logic_vector(3 downto 0);
validreout: out std_logic;
readreout: out std_logic
end framestore;
architecture structure of framestore is
signal hold: std_logic_vector(3 downto 0);
signal address: std_logic_vector(14 downto 0);
signal tempvalid: std_logic;
signal tempread: std_logic;
signal readEn_RE: boolean;
signal valid_RE: boolean;
signal reg: std_logic;
component ram4bits is
PORT
address : IN STD_LOGIC_VECTOR (14 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
end component;
begin
process(clk,reset,valid,readEn)
begin
if(reset = '1') then
address <= "000000000000000";
reg <= '0';
elsif(clk'event and clk = '1') then
reg <= valid;
if(valid_RE or readEn_RE) then
address <= rwaddressstart;
elsif(valid = '1' or readEn = '1') then
address <= address + '1';
end if;
elsif(clk'event and clk = '0') then
tempread <= readEn;
tempvalid <= valid;
end if;
end process;
store: ram4bits port map(address => address,clock => clk,data => input,wren => reg,q=>hold);
readEn_RE <= tempread = '0' and readEn = '1';
valid_RE <= tempvalid = '0' and valid = '1';
output <= hold when readEn = '1' else "0000";
validreout <= '1' when valid_RE else '0';
readreout <= '1' when readEn_RE else '0';
addressout <= address;
holdout <= hold;
end structure;
