tde_m
8 years agoSystolic array: channel indexing
Hello, I'm trying to write a basic example of a systolic array. It is essentially a chain of processing elements connected through channels: the first one read data from memory and inject it into th...
HRZ
8 years agoYou seem to be confusing replication of NDRange kernels with Single Work-item ones. The former is completely controlled by the compiler and you CANNOT use it to design a systolic array since you cannot customize the kernel copies. What the guide is referring to is replication of Single Work-item kernels where you can then use the get_compute_id() function to get a compile-time constant ID for each kernel copy and use it to customize each copy and its channel connections. In your case the get_global_id() returns a run-time variable value which cannot be used as channel index.
