8 years agoSystemVerilog error: parameter with complex/aggregate value must have a type
Hi, everyone. I am the first time asking the questions here. I want to declare a double array parameter. However, I meet an error as below. Can someone help me? Thank you very much. ...
8 years agoThank you very much. I try it.
However, I meet another error. Error (10161): Verilog HDL error at command_lookup.v(87): object "bit" is not declared. Verify the object name is correct. If the name is correct, declare the object. Do you know what it is?
