8 years agoSystemVerilog error: parameter with complex/aggregate value must have a type
Hi, everyone. I am the first time asking the questions here.
I want to declare a double array parameter. However, I meet an error as below. Can someone help me? Thank you very much. error (10709): systemverilog error at command_lookup.v(87): parameter with complex/aggregate value must have a type parameter command = { // Clear the screen and set cursor position to home
8'h1B, // Esc
8'h5B, // [
8'h6A, // j
// Set the cursor position to row 0 column 3
8'h1B, // Esc
8'h5B, // [
8'h30, // 0
8'h3B, // ;
8'h33, // 3
8'h48, // H
// Text to print out on the screen
8'h48, // H
8'h65, // e
8'h6C, // l is lowercase L, not number one
8'h6F, // o
8'h20, // Space
8'h46, // F
8'h72, // r
8'h6F, // o
8'h6D, // m
// Set the cursor position to row 1 column 4
8'h1B, // Esc
8'h5B, // [
8'h31, // 1 is number one not L
8'h3B, // ;
8'h34, // 4
8'h48, // H
8'h44, // D
8'h69, // i
8'h67, // g
8'h69, // i
8'h65, // e
8'h6E, // n
8'h74, // t
8'h00 // Null
};3 Replies
Change your declaration to
It is a good idea for any parameter declaration.parameter bit command = { // Clear the screen and set cursor position to home - Altera_Forum
Thank you very much. I try it.
However, I meet another error. Error (10161): Verilog HDL error at command_lookup.v(87): object "bit" is not declared. Verify the object name is correct. If the name is correct, declare the object. Do you know what it is? - Altera_Forum
have you saved the file with .sv extension? it is trying to compile it as verilog, not SV
