BLee15
7 years agoSystemVerilog attribute with multi-line string has weird behavior
Version: Quartus Prime Version 18.1.1 Build 646 04/11/2019 SJ Lite Edition When I tried to synthesis following Verilog code: (* altera_attribute = "-name VIRTUAL_PIN ON -to a[*]; \
-name VIR...
MEIYAN_L_Intel
7 years agoHi,
It is mentioned that random crashing behavior is observed in your previous reply, do you see a consistent error message for the error? I can see the same error message is issued by the software due to limited systemverilog language support in the Lite Edition of the software.
BLee15
7 years agoI mentioned that this source code caused crash (core dump) of quartus_map (which is different from very first source code):
(* altera_attribute = string'("-name VIRTUAL_PIN ON -to a[*]; \
-name VIRTUAL_PIN ON -to b[*]; \
-name VIRTUAL_PIN ON -to c[*]") *)
module top(
input logic raw_clock,
input logic[17:0] a,
input logic[17:0] b,
output logic[35:0] c
logic clock;
pll pll(
.inclk0(raw_clock),
.c0(clock)
lpm_mult #(
.lpm_widtha(18),
.lpm_widthb(18),
.lpm_widthp(36),
.lpm_pipeline(1),
.lpm_representation("UNSIGNED")
) mult(
.clock(clock),
.dataa(a),
.datab(b),
.result(c)
endmoduleDisclaimer: I can accept that the very first source code of this thread is due to limit support of lite edition.
