BLee15
7 years agoSystemVerilog attribute with multi-line string has weird behavior
Version: Quartus Prime Version 18.1.1 Build 646 04/11/2019 SJ Lite Edition When I tried to synthesis following Verilog code: (* altera_attribute = "-name VIRTUAL_PIN ON -to a[*]; \
-name VIR...
MEIYAN_L_Intel
7 years agoHi,
It is mentioned that random crashing behavior is observed in your previous reply, do you see a consistent error message for the error? I can see the same error message is issued by the software due to limited systemverilog language support in the Lite Edition of the software.
- BLee157 years ago
I mentioned that this source code caused crash (core dump) of quartus_map (which is different from very first source code):
(* altera_attribute = string'("-name VIRTUAL_PIN ON -to a[*]; \ -name VIRTUAL_PIN ON -to b[*]; \ -name VIRTUAL_PIN ON -to c[*]") *) module top( input logic raw_clock, input logic[17:0] a, input logic[17:0] b, output logic[35:0] c ); logic clock; pll pll( .inclk0(raw_clock), .c0(clock) ); lpm_mult #( .lpm_widtha(18), .lpm_widthb(18), .lpm_widthp(36), .lpm_pipeline(1), .lpm_representation("UNSIGNED") ) mult( .clock(clock), .dataa(a), .datab(b), .result(c) ); endmoduleDisclaimer: I can accept that the very first source code of this thread is due to limit support of lite edition.
