BLee15
7 years agoSystemVerilog attribute with multi-line string has weird behavior
Version: Quartus Prime Version 18.1.1 Build 646 04/11/2019 SJ Lite Edition When I tried to synthesis following Verilog code: (* altera_attribute = "-name VIRTUAL_PIN ON -to a[*]; \
-name VIR...
sstrell
7 years agoAs you show in your last example, you can just use whitespace (carriage return between words). There's no need to even use the backslash.
But did you check which language interpreter was being used as I mentioned?
#iwork4intel
BLee15
7 years agoI'm pretty sure the language is SystemVerilog indeed.
- The file extension is ".sv" (instead of ".v")
- If it were Verilog mode, the keyword like 'logic' and/or 'always_ff' would be produce error.
