SystemVerilog attribute with multi-line string has weird behavior
Well, I guess I learned something today!
Perhaps it works in other parts of SV code but not in the middle of attributes. Have you tried that?
It might also be good to go into the Settings (from the Assignments menu) and under Verilog, make sure the SystemVerilog interpreter is set. Perhaps it's trying to synthesize your code as Verilog-2001 instead of SystemVerilog.
#iwork4intel
- BLee157 years ago
When I tried backslash-newline in module parameter like this:
(* altera_attribute = "-name VIRTUAL_PIN ON -to a[*]; -name VIRTUAL_PIN ON -to b[*]; -name VIRTUAL_PIN ON -to c[*]" *) module top( input logic raw_clock, input logic[17:0] a, input logic[17:0] b, output logic[35:0] c ); logic clock; pll pll( .inclk0(raw_clock), .c0(clock) ); lpm_mult #( .lpm_widtha(18), .lpm_widthb(18), .lpm_widthp(36), .lpm_pipeline(1), .lpm_representation("UNS\ IGNED") ) mult( .clock(clock), .dataa(a), .datab(b), .result(c) ); endmoduleI got following error message:
Warning (272007): MGL_INTERNAL_WARNING: ( The parameter value is not one of the pre-specified values in the value list.) lpm_mult|LPM_REPRESENTATION The value assigned is UNS IGNED and the valid value list is UNSIGNED|SIGNED Error (272006): Parameter error: LPM_REPRESENTATION parameter with value UNS IGNED must be set to SIGNED or UNSIGNEDWhie it retains string type (i.e. not convertered to bitstream), it seems that the newline character is not ignored.
The following SystemVerilog source code, which includes type casting for attribute, caused crash (core dump) of quartus_map:
(* altera_attribute = string'("-name VIRTUAL_PIN ON -to a[*]; \ -name VIRTUAL_PIN ON -to b[*]; \ -name VIRTUAL_PIN ON -to c[*]") *) module top( input logic raw_clock, input logic[17:0] a, input logic[17:0] b, output logic[35:0] c ); logic clock; pll pll( .inclk0(raw_clock), .c0(clock) ); lpm_mult #( .lpm_widtha(18), .lpm_widthb(18), .lpm_widthp(36), .lpm_pipeline(1), .lpm_representation("UNSIGNED") ) mult( .clock(clock), .dataa(a), .datab(b), .result(c) ); endmodule - BLee157 years ago
The following source code, which uses concatenation operator for attribute, synthesised as expected without any errors.
(* altera_attribute = { "-name VIRTUAL_PIN ON -to a[*]; ", "-name VIRTUAL_PIN ON -to b[*]; ", "-name VIRTUAL_PIN ON -to c[*]" } *) module top( input logic raw_clock, input logic[17:0] a, input logic[17:0] b, output logic[35:0] c ); logic clock; pll pll( .inclk0(raw_clock), .c0(clock) ); lpm_mult #( .lpm_widtha(18), .lpm_widthb(18), .lpm_widthp(36), .lpm_pipeline(1), .lpm_representation("UNSIGNED") ) mult( .clock(clock), .dataa(a), .datab(b), .result(c) ); endmoduleAs it seems that string concatenation is better option than backslash-newline idiom, I'll use this method. However, could you consider investigating this issue, especially the crashed case?
