11 years agoHi Tricky,
Thanks for the tip, I did the change based on your suggestion and the code seems now cleanest, but the function next_state isn´t still working as expected, and I presume that compiler is creating extra registers which could avoid the proper functioning. I´m putting bellow the last version of the code, and also attached the .vcd testbench generated by Simulation Waveform editor of QuartusII. Just to review the need: The basic idea is to create of a function that once called, increments a sub-state at each clock event, and keep itself in the main state while not reached the last sub-state; on other words, it´s a kind of run sub states at a bottom layer. Can you see something clearly wrong on this program regarding to the fundamentals of coding on Verilog/SV ?parameter ST_SIZE = 4 ;
parameter ST_START = 4'b0 ;
parameter ST_STEP = 4'b1 ;
module moore_mac
input clk, data_in, reset,
output reg data_out
//******************************* Parameter definitions
parameter S0 = ST_START ;
parameter S1 = S0 + ST_STEP ;
parameter S2 = S1 + ST_STEP ;
parameter S3 = S2 + ST_STEP ;
parameter S4 = S3 + ST_STEP ;
parameter S5 = S4 + ST_STEP ;
parameter S6 = S5 + ST_STEP ;
parameter S7 = S6 + ST_STEP ;
parameter S8 = S7 + ST_STEP ;
parameter S9 = S8 + ST_STEP ;
parameter S5_3 = ST_START ;
parameter S5_2 = S5_3 + ST_STEP ;
parameter S5_1 = S5_2 + ST_STEP ;
parameter S5_0 = S5_1 + ST_STEP ;
//******************************* Type declarations
typedef struct packed {
logic Level_main ; // Current state ( main level )
logic Level_sub ; // Target sub-state ( 1 depth bellow )
logic Level_subcurr ; // Current sub-state ( 1 depth bellow )
} FSM ;
//******************************* Varable declarations
reg res = 0 ;
reg ires = 0 ;
FSM StateMachine ;
//********************************** Determine the next state
always @ ( posedge clk )
begin
ires <= reset ;
res <= ires ;
end
always @ ( posedge clk or posedge res )
begin
if (res)
begin
StateMachine.Level_main <= S0 ;
end
else
begin
case (StateMachine.Level_main)
S0:
StateMachine.Level_main <= S1;
S1:
if (data_in) StateMachine.Level_main <= S1;
else StateMachine.Level_main <= S2;
S2:
else StateMachine.Level_main <= S3;
S3:
StateMachine.Level_main <= S4;
S4:
begin
StateMachine.Level_main <= S5;
StateMachine.Level_sub <= S5_0;
StateMachine.Level_subcurr <= S5_3;
end
S5:
StateMachine <= next_state (
StateMachine.Level_main ,
StateMachine.Level_sub ,
S6:
StateMachine.Level_main <= S7;
S7:
StateMachine.Level_main <= S8;
S8:
StateMachine.Level_main <= S9;
S9:
StateMachine.Level_main <= S0;
default:
endcase
end
end
//********************************** Determine the output value
begin
case ( StateMachine.Level_main )
S0:
data_out <= S0 ;
S1:
data_out <= S1 ;
S2:
data_out <= S2 ;
S3:
data_out <= S3 ;
S4:
data_out <= S4 ;
S5:
data_out <= S5 ;
S6:
data_out <= S6 ;
S7:
data_out <= S7 ;
S8:
data_out <= S8 ;
S9:
data_out <= S9 ;
default:
data_out <= S0 ;
endcase
end
// Increments sub-state and get out to next main state after completion
function FSM next_state(
input logic valStateBefore ,
input logic valSubstateBefore ,
input logic valSubstateCurrent
FSM next_state_return ;
if ( valSubstateCurrent < valSubstateBefore ) // increments sub-state, but keep main state unchanged
begin
next_state_return.Level_main = valStateBefore ;
next_state_return.Level_sub = valSubstateBefore ;
next_state_return.Level_subcurr = valSubstateCurrent + ST_STEP ;
end
else // increments main state
begin
next_state_return.Level_main = valStateBefore + ST_STEP ;
next_state_return.Level_subcurr = valSubstateCurrent ;
end
return next_state_return ;
endfunction
endmodule Whatever change I do, nothing happens with the current substate, as bellow: http://www.alteraforum.com/forum/attachment.php?attachmentid=10231&stc=1 Please note that this code has only meant to be an opportunity to have the first contact with the language, it may contain other problems, but the focus right now is the unexpected behavior of the function.
