13 years ago
system.h generation with a script
I have built a design with QSYS on Quartus 13.0. I see it generates a "<my_design>.sopcinfo" file. If we run NIOS IDE most likely it will generate a "system.h" file that can be used as memory map header files in the C codes.
I am not going to run NIOS IDE since I don't want to be involved in C code compilation! I just need a header file for my RTL simualtion environment. is there any script to read the sopc file and generate a "system.h" or any header file that I can use?
1 Reply
    We use the nios2-bsp command in our build system to automate generation of the Altera HAL BSP.
