10 years agoSystem Console under Linux (Quartus Prime Programmer and Tools package)
Hello, I need to launch System Console under Linux , so I've installed a "quartus prime programmer and tools" package (QuartusProgrammerSetup-16.0.0.211-linux.run)
However, there is no system-console binary. Installation wizard offers to launch it and fails. I've checked installed files and indeed it is not there. Do you know if it is supported under Linux ? And how can I install it? Thanks, Roman3 Replies
I was able to install system-console as a part of Full Quartus Prime package.
However it hangs during startup: I start it from console using command:
Here is what I'm seeing in log tail:system-console -debug -cli
There should be a TCL command promt, but it hangs ..... Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole$PluginDiscovery run INFO: Finished initialization Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole logWarning WARNING: Could not register IService packet Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole logWarning WARNING: A service named 'packet' is already registered. Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole logFine FINE: Native library path is /home/ripopov/apps/altera/16.0/quartus/linux64 Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole logFine FINE: Connection type USB hash 9DE6D87621243DDC1327 index 1 device 1 Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole logInfo INFO: Finished discovering JTAG connections Jul 15, 2016 3:48:24 PM com.altera.systemconsole.internal.core.SystemConsole logFine FINE: Connection type JTAG hash NULL index null device 2 Jul 15, 2016 3:48:30 PM com.altera.systemconsole.internal.core.SystemConsole logInfo INFO: Finished discovering USB connections - Altera_Forum
After some random experiments I've found out that System Console hangs when design "USB Debug master" is loaded on FPGA.
If I reset FPGA, System Console starts and I can see a TCL promt. Howver, after programming FPGA from System Console I still can't access a USB Debug master: when I try:
I got:% get_service_paths master
I've checked the same design on Windows 8.1 and it works, I'm able to explore same FPGA design using System Console. does a "usb debug master" requires some additional driver installation on linux ?error: Filesystem is not ready while executing "get_service_paths master"I've used this howto http://www.fpga-dev.com/altera-usb-blaster-with-ubuntu/ to enable on-board Byte Blaster II on my stratix-v gx board.
Probably the source of issue is my Linux distro: I use Ubuntu 14.04 and Altera supports only RHEL 6 and 5.
Did someone managed to work with System Console and USB Debug master on RHEL?
