9 years agoSystem Console Oscilloscope function does not aleays work with NIOS
I am doing data acquisition using the ADC in the MAX 10. I am trying to us the oscilloscope function of the System Console to monitor the ADC inputs.
When I am using it without the NIOS it works fine. When I install the NIOS Processor and call System Console from Eclipse it will work occasionally but usually I get the following error messages: master_write_32: java.lang.NullPointerException while executing "master_write_32 $sequencer_service 0x0 1 " (procedure "::adc_toolkit::trigger_sample_trace" line 39) invoked from within "::adc_toolkit::trigger_sample_trace $channel_number $sample_size" (procedure "::adc_toolkit::trigger_sample" line 3) invoked from within "::adc_toolkit::trigger_sample $channel_number $sample_size " (procedure "::adc_toolkit::scope_test" line 28) invoked from within "::adc_toolkit::scope_test" ("uplevel" body line 1) invoked from within "uplevel 1 $command_string " (procedure "::adc_toolkit::debug_timer_run" line 7) invoked from within "::adc_toolkit::debug_timer_run ::adc_toolkit::scope_test {scope test}" ("after" script) Any idea why it sometimes works and sometimes fails? I am using Quartus Version 15No RepliesBe the first to reply
