System Console and monitor service
I'm testing the monitor service from system console.
Below the example code (from help in system console) with modified registers. 0x00004014 is a register with is changing at 2 hz and 0x00004024 at 1 hz. With some C code I verified that the registers are indeed changing.
See attached for code
I expect something like:
0x00004014: 0x00 (100 ms) 0x00004024: 0x00 (100 ms)
0x00004014: 0x01 (100 ms) 0x00004024: 0x00 (100 ms)
0x00004014: 0x00 (100 ms) 0x00004024: 0x01 (100 ms)
0x00004014: 0x01 (100 ms) 0x00004024: 0x01 (100 ms)
But I get:
As you can see, the 0x00004024 is a copy of 0x00004014. I now for sure the values of the register are correct and changing.
I tested this two way's, one with an C application and two with system console with 20 bytes read on the callback function.
Output of C:
0x00004014: 0x00 0x00004024: 0x00
0x00004014: 0x01 0x00004024: 0x00
0x00004014: 0x00 0x00004024: 0x01
0x00004014: 0x01 0x00004024: 0x01
Code:
monitor_add_range $monitor_path $master_path 0x00004014 20
#TCL callback procedure for the monitor service
proc example_callback_proc {monitor_path master_path} {
set w1 [monitor_read_data $monitor_path $master_path 0x00004014 20]
set i1 [monitor_get_read_interval $monitor_path $master_path 0x00004014 20]
puts "0x00004014: $w1 ($i1 ms)"
Output of system console with change of size in read action:
0x00004014: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 (100 ms)
0x00004014: 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 (100 ms)
0x00004014: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x00 0x00 0x00 (100 ms)
0x00004014: 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x00 0x00 0x00 (100 ms)
From the documantion: "More ranges can be added. with monitor_add_range". This is also shown in the example. So I don't understand why this is not working.
Do some of you have an idea?
TO_BE_DONE
I'm having the exact same issue with some code I wrote for system console. Has anyone figured this out? Should I start an Altera SR?
