11 years agoI can confirm this. In order to get the trace system to connect automatically to JTAG you must select YES to "Export interfaces for connection to manual debug fabric"
That is correct you have to select "manual" in order to get automatic connection to JTAG. If you leave the setting in its default then the trace will not connect. This does contradict the documentation which states: --- Quote Start --- If you select the JTAG connection to the host, then the Quartus II software automatically makes the pin connection during synthesis. --- Quote End --- The default settings (No; JTAG) will NOT work. This is with Quartus II 14.0.2.
