I suspect that the way you are using the variables means that it thinks it doesnt need the value from clock cycle to clock cycle, meaning random_num is always '0'. Or it could be because you have the random_num output outside of the clock.
Either way, I would use signals instead of variables.
but for a first attempt, try re-arranging the code like this:
process(clk)
variable rand_temp : std_logic_vector(width-1 downto 0):=(width-1 => '1',others => '0');
variable temp : std_logic := '0';
begin
if(rising_edge(clk)) then
random_num <= rand_temp;
temp := rand_temp(width-1) xor rand_temp(width-2);
rand_temp(width-1 downto 1) := rand_temp(width-2 downto 0);
rand_temp(0) := temp;
end if;
end process;
