llpo
3 years agoSynthesize NIOS II with different .qsf and no time_limited
We are 100% new to Quartus (and FPGA in general). I have a project (the DE1-SoC Computer System that comes by default with the University Program when using NIOS II), that I would like only to...
KellyJialin_Goh
3 years agoHi,
Thank you for your feedback.
Unfortunately, the DE1_SoC_Computer project is a default design example, you can only use the Nios II/e core to avoid the time_limited part as stated from the manual.
Yes, the Nios II/e core will have some floating point limitations, but you may change the core to a fast core for other projects you wish to compile.
I have attached a screenshot on the NIOS II processors (e and f) for your reference where you are able to change.
Hope this clarify your doubts.
Thank you.
Kelly
KellyJialin_Goh
3 years agoHi,
Attached here is a screenshot on how to change the cores to fast or economy for the DE1 SoC based on your project needs after you have selected NIOS II processor on Platform Designer:
Thank you.
Kelly
