10 years agoSynthesize multipliers on distributed logic?
Hello, I want to synthesize a symmetric FIR filter with 116 taps. Thus, the design should infer 58 multipliers. As I start the design flow for a Cyclone V (5CSEMA4U23C6) with 84 DSP blocks, everyt...
10 years ago --- Quote Start --- But does it also mean, that a multiplier cannot be synthesized to the distributed logic? --- Quote End --- In Assignments->Settings->Compiler Settings->Advanced Settings (Synthesis) you can set dsp block balancing to logic elements, but then it will only infer LEs. You may want to experiment with these settings.
